I have been thinking about installing a set of 1.6 rockers on my 89 L98. I was just wondering if any of you have installed these on a similar engine, and if so what kind of performance gains did you see. The rockers I am looking at are from GM performance parts and they sell for $300.00 a set.
I have heard on the L98 its better to go wiht a 1.6/1.5 mix. But the LT1 likes 1.6 all the way around. But you can gain I belive 10-15 hp :confused: I havent installed mine yet still waiting on extra parts for the new heads. Check with Nathan Plemons or Glock94 they have had theres for a while but with the LT1 I dont know anyone wiht the L98.
This is very interesting. I'd like to learn more about it. You don't mind if I start a thread about it to get more possible input?
BTW, to L98 Punk, I did so many other mods at the same time as my 1.6RR's, that I couldn't qualify an accurate answer. One thing is for sure: my L98 pulls very hard now.
TPIS "Insider Hints" says that 1.6s on the intake are worth about 10-12hp; 1.6s on the exhaust side don't give any gain but effect idle.
I installed 1.6:1 ProMagnums on int & exh. The idle is maybe even smoother than with stock rockers. I was having knock count problems at the time so don't have time slip data to verify results, but I think 10hp gain is reasonable.
Also I installed new valve springs & seals, tossed the oil shedders, installed Ti retainers & 10deg locks with 7/16" studs to raise my safe rev limit.
I've had the 1.6's for a while, they just haven't been in my car :D. I bought them over the summer and just recently put them in with the new engine. I only have 570miles on the car since the rebuild, so I don't have top end experience with them yet, but I can tell you that they SURE ARE NOISY! I am using the non-adjustables though, which is probably why they are so noisey. I will be switching to Pro Magnums or the sort over summer probably. If you can wait, I'll sell you these for $150 over summer :D. I don't know what kind of difference in idle they make because I put the HOT cam in at the same time, so it was just plain bad :).
