LED Tail Lights
Old Dec 23, 2009 | 03:50 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Default LED Tail Lights
A friend just bought a set of LED tail lights for his '95 coupe. As I understand he needs to replace the turn signal flasher which is located behind the DIC with a flasher for the emergency flashers. Is this correct?
TIA
Old Dec 23, 2009 | 07:27 PM
c4cruiser's Avatar
c4cruiser
Unless his LED tail lamp set came with resistors already installed for the LED's, he will need an electronic flasher for the turn signals. LED's generate very little current resistance so the mechanical turn signal flasher unit will probably not work at all or the lights will flash very flash. The electronic flasher will flash at a set rate with no real regard for resistance in the circuit.
The hazard flasher "should" be OK as it is for that purpose.
Old Dec 23, 2009 | 08:22 PM
Mark C5's Avatar
Mark C5
Thanks, is the flasher located behind the DIC?
Old Dec 23, 2009 | 09:41 PM
-=Jeff=-'s Avatar
-=Jeff=-
no, it should be behind the lower hush panel near the steering wheel ( assuming it is the same as my 90)
Old Dec 23, 2009 | 10:02 PM
redrose's Avatar
redrose
key 'on', engine 'stopped', turn signal 'on'...follow your ear to the 'click', fingertip feel for exact source and pull.
'electro-mechanical' flasher abt $12 at napa and most 'discount' auto parts stores
To LED Tail Lights
