LT1 valve cover gaskets
Old Dec 23, 2009 | 04:15 PM
surfer92's Avatar
surfer92
Default LT1 valve cover gaskets
Does ANYBODY make a gasket that fits properly???
I have tried Felpro, Delco and both are a inch to long, I cut them shorter and I get leaks where cut and I used Form a gasket and Permatex blue on the cuts.
Old Dec 23, 2009 | 04:49 PM
5POINT7's Avatar
5POINT7
: I was about to change mine, curious to hear about some good ones.
mazdaverx7's Avatar
mazdaverx7
i recently used moroso silicone gaskets on my 84 (obviously not an LT-1) and where the fel pro's leaked, the moroso's held up flawlessly.
Old Dec 23, 2009 | 04:50 PM
mazdaverx7's Avatar
mazdaverx7
here are the pics of the part number and packaging of the gaskets that i used:
Old Dec 23, 2009 | 05:54 PM
davidf4925's Avatar
davidf4925
I just did mine on my 95 ( in july), I bought the felpro ones. at first glance they do look to long, but I promise you they snap right in place. I havn't had any leaks since.
Old Dec 23, 2009 | 10:23 PM
surfer92's Avatar
surfer92
Mine did not fit right in, when I tried to get mine to fit, I had a bubble an inch high.
Old Dec 23, 2009 | 10:24 PM
surfer92's Avatar
surfer92
MAVDAVERX7, sorry yours won't fit a LT1.
Old Dec 24, 2009 | 03:41 AM
miscstudent's Avatar
miscstudent
I literally did mine this week and at first try they seem about an inch too long. You kind of feed it into the channel, push back on it, and feed more in and push back on it etc. etc. Eventually it all fits. I used the fel-pro one with some random gasket sealant and it worked very well. I really recommend it.
Old Dec 24, 2009 | 06:25 AM
Red-Lt1's Avatar
Red-Lt1
Same here. Felpro and no leaks.
Old Dec 24, 2009 | 06:50 AM
Weav's Vet's Avatar
Weav's Vet
They all will seem a little long. Just keep pushing back on them. they'll fit. I just used some from NAPA. Same thing, they don't leak one bit.
Old Dec 24, 2009 | 07:01 AM
toptechx6's Avatar
toptechx6
Understand that most who reply concerning LT1 gaskets have the later composite covers, the gaskets for your 92 are entirely different.
If the Fel Pro VS50088 set will not fit try GM PN 14088564 (2 required).
Old Dec 24, 2009 | 10:06 AM
mazdaverx7's Avatar
mazdaverx7
good call. i didn't think about the LT1 having the center bolt valve covers. thanks for catching that
Old Dec 24, 2009 | 10:46 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Its been a long time since I bought mine - do a search, IIRC there was a part number for a pack of two and the single gasket. I got the pack of two - they were blue instead of the stock orange and fit perfectly.
I can't find the number but it was fairly inexpensive.
Old Dec 24, 2009 | 11:59 AM
JAKE's Avatar
JAKE
Same thing here, at least an inch!
I sent them back to Summit and just re-used the ones that were already on the covers. Not my original plan but "ya do what ya gotta do."
Stranger still is they were shown as being specifically for the LT1 and cost a pretty penny to boot.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 24, 2009 | 12:37 PM
92LRC's Avatar
92LRC
the blue ones are for 91's and they fit the 92 perfectly. they're under 20 bucks for the package of 2.
I beleive you can also look for 93 camaro's as they didn't have the composite covers.
Old Dec 24, 2009 | 12:54 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I bought mine in the local auto parts and there is no issues.
Old Dec 24, 2009 | 01:09 PM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Used the one's from NAPA on my 95, no leak or fitament issues .
Old Feb 12, 2017 | 01:39 PM
celticvette's Avatar
celticvette
3rd Gear
Default valve cover gaskets
start with one corner and push the gasket together as you go around... fits like a glove
Old Feb 12, 2017 | 01:40 PM
celticvette
3rd Gear
start at one corner and push the gasket together as you push it into the groove.. fits like a glove!
To LT1 valve cover gaskets
