abs asr lights
Old Mar 3, 2002 | 01:16 PM
davrober's Avatar
davrober
Default abs asr lights
I purchased a 96 lt1 in Florida and it was shipped up here on transporter,and chained down. There were no lights on the panel whenit was loaded. I started it up and the abs off light stays on, and the asr off light and asr service light remain on.I checked the 30 amp fude and it was blown so I replaced it . the lights still stay on but the fuse is now ok. Any ideas what is causing thiese system to indicate they need service, or do they need to be reset somehow now that the fuse is ok. I checked the brake fluid level and its were it should be . Any help would be appreciated.
Found 30 amp blown abs/asr fuse under hoo, furthure investigation located crushed wire harness next to chain hook by left rear wheel. ABS wire was split , respliced it replaced fuse and just need to clear code from ebtcm . Thanks for all that wrote.
[Modified by davrober, 1:42 AM 3/9/2002]
Old Mar 3, 2002 | 02:03 PM
bogus's Avatar
bogus
Default Re: abs asr lights (davrober)
there is a chance that one of the rear wheel sensors was damage in shipping.
I would check that first. I doubt if much serious was hurt...
Old Mar 3, 2002 | 03:51 PM
Red Dwarf's Avatar
Red Dwarf
Disconnect the battery for a couple of minutes. :cheers:
To abs asr lights
