Porting pics!
Old Mar 3, 2002 | 01:59 PM
Sliding's Avatar
Sliding
Default Porting pics!
This is what i've done so far. I will also do some porting on
intake manifold but not siamesed thing.
Could all this be worth 10-15 PS?
What do you think? :cool:
Old Mar 3, 2002 | 04:10 PM
GlockLT4's Avatar
GlockLT4
Default Re: Porting pics! (Sliding)
:cool:
Old Mar 3, 2002 | 04:32 PM
LPDesRoche's Avatar
LPDesRoche
You should really try the siamese trick on the base. It has been dyno proven to work. You are already there, you may as well remove the lower and go for it. If you did the lower as well, then you may see somewhere between 15-20 HP.
Old Mar 3, 2002 | 04:40 PM
pablocruise's Avatar
pablocruise
Default Re: Porting pics! (LPDesRoche)
Just be VERY conservative with the intake tract that feeds #5 and #7 intakes. I am not sure what motor you have, but I think it looks like the L98. Your firing order is 1-8-4-3-6- 5- 7-2 ?
Old Mar 3, 2002 | 05:58 PM
Juliet's Avatar
Juliet
Got a before pic? :)
Old Mar 4, 2002 | 07:03 PM
Sliding's Avatar
Sliding
Default Re: Porting pics! (Juliet)
Runners - before and after.
I don't have any other before and after pics.
I have manifold down, but i'm affraid to siamesse the ports because in some previous posts there were some diff. in opiniions (about cyl. 5&7).
But i have already ported the intake manifold ports (upper part)
I'm not sure should i port the lower part also, because it's square shape
and injectors sit there.
Did anybody port this also - any pics?
:chevy
Old Mar 4, 2002 | 07:11 PM
KYVette90's Avatar
KYVette90
I think someone on here said that knife edges were not good. You might want to make them a little more rounded to allow smooth air flow. Here's a pic of my plenum porting. I did feel a noticable difference in trottle response and the car reaches higher rpms quicker now. Be careful about how much material you remove from the seal surfaces, if you take too much off you can suck the gaskets right out from between the runners and the plenum, causing vaccum leaks. Peace.
Old Mar 4, 2002 | 07:12 PM
BBA's Avatar
BBA
You should port the base. Basically, use the intake gasket for a stencil and match the ports perfectly. Make sure the cylinder head ports are matched as well...you do not want the intake manifold larger than the heads intake ports.
I think siamesing the base is also a good idea. I wouldn't worry about 5-7 scavengine...it's only a problem on 'wet' manifolds ( IE: carb or TBI designs ). Heck, even for carbs, single plenums put 5-7 almost together anyway...no problems there.
Old Mar 4, 2002 | 07:13 PM
LT5's Avatar
LT5
:cool:
Old Mar 4, 2002 | 07:36 PM
Sliding's Avatar
Sliding
Default Re: Porting pics! (KYVette90)
Thanks for all inputs!
I have some more work to do.
When all will be done I'll send you pics of finished products,
before puting it back together.
Old Mar 4, 2002 | 07:58 PM
Bill Reid's Avatar
Bill Reid
Very :cool:
Old Mar 4, 2002 | 09:43 PM
Juliet's Avatar
Juliet
Sliding & KYVette - Thanks for the photos. :) As they say, a picture is worth 1000 words. :seeya ~Juliet
Old Mar 4, 2002 | 09:52 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Very nice :cool:
Old Mar 5, 2002 | 12:15 AM
Jsailor24's Avatar
Jsailor24
what happened to the idle circuit tube? What did you use to port them? Did you enlarge the entire runner? I couldnt get mine out because the fuel rail wont come out.
Old Mar 5, 2002 | 01:47 PM
Sliding's Avatar
Sliding
Default Re: Porting pics! (Jsailor24)
If you are thinking about the picture in my previous post, these are not the same runners.
I made this photo when i ported one runner and the other is stock.
I didn't port the whole lenght of runners because they are too thin.
The fuel rail should come off easy.
You must take off all bolts (see pictures) and fuel income and return tubes
(pic. 2).
When everything is disconnected only rubber seals on injector (pic. 3) can
hold fuel rail but it should go out easy.
I'm sorry if my posts are coming late, but it's big diff. in time.
To Porting pics!
