Replacing two way check valve
Old Dec 25, 2009 | 05:26 PM
Baldfart's Avatar
Baldfart
Default Replacing two way check valve
I have a 1987 convertable. I was replacing the two way check valve that is sitting to the left of the distributer. No problem with the vacuum line from the intake and a rubber line that lead to the left toward the master cylinder. However, the hard plastic came from around the back of the distributer broke (very brittle). I cannot find where the line broke from. Pulled the distributer cap to see better but I can not find the missing end. Does anybody know where this line goes to?
Old Dec 25, 2009 | 05:32 PM
JackDidley's Avatar
JackDidley
Its taped up with a bundle of wires that go into the car. You will have to peel back the tape to find it.
Old Dec 25, 2009 | 07:59 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I too had this problem on an 87 vert but with a different line. I took it to the local auto parts store. They had some black hose that was the same size that they sold by the foot. It was much softer than the stuff that was on there after 60,xxx miles.
Fortunately I was able to find where the beginning and end were.
Can you even buy those check valves in case they are bad or broken?
Old Dec 25, 2009 | 08:11 PM
Baldfart's Avatar
Baldfart
I have previously replaced a section of brittle plastic line. The check valve is available from Chevy. I got some vacuum line from NAPA that slid over the plastic line nice and tight and replaced the bad section. Hopefully I can repair this line the same when I find the missing end.
Last edited by Baldfart; Dec 25, 2009 at 08:15 PM. Reason: add info on check valve
Old Dec 25, 2009 | 08:18 PM
rodj's Avatar
rodj
As mentioned above , is part of the main wiring harness that runs across the firewall. Are going to have to open up the harness (PITA ) until you find the broken end.
Apparently available from NAPA for a couple of $$
Old Dec 25, 2009 | 08:57 PM
Baldfart's Avatar
Baldfart
Does that vacuum line go through the firewall the same place the wiring harness does? Next to the transmission dipstick?
Old Dec 25, 2009 | 09:00 PM
JackDidley's Avatar
JackDidley
Yes its for the heater control. Its IN the wire harness.
Old Dec 26, 2009 | 05:26 AM
floridamale's Avatar
floridamale
To Replacing two way check valve
