Who got the chip??
Old Mar 3, 2002 | 05:03 PM
C4RAG's Avatar
C4RAG
Default Who got the chip??
Ok boys and girls, who has the best stage one chip and why is it better than the others?? Need one for my 1989 6 Speed Roadster and they all look the same from where i am sitting... Only upgrade I have is a tad bigger injectors, and an adjustable regulator...
Old Mar 3, 2002 | 05:27 PM
chamilton's Avatar
chamilton
Default Re: Who got the chip?? (C4RAG)
Hypertech Thermomaster. I put this one in, and it made a big difference. You take a hit on gas mileage, and have to use premium gas, but it works good for me. You do need to put in a 160 degree themostat, and the chip makes the auxilliary fan run more often, as it tries to keep the car below 200 degrees.
Old Mar 3, 2002 | 05:39 PM
FSTRNU's Avatar
FSTRNU
Default Re: Who got the chip?? (chamilton)
Hypertech suxs :U only thing it does is turn your fans on sooner. Fastchips.com for a Ed Wright chip or try thunderracing.com for a chip they also do dyno tuning.
[Modified by 93Zeus, 3:39 PM 3/3/2002]
[Modified by 93Zeus, 10:03 PM 3/3/2002]
Old Mar 3, 2002 | 07:18 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
better to get a custom one rather than a generic one. When my time comes, I'm going custom.
Old Mar 3, 2002 | 07:20 PM
vader86's Avatar
vader86
With those mods, you dont need a chip. If you want your fans to come on sooner have one custom burned but dont pay Hypertech $200 just to make your fans come on earlier.
Old Mar 3, 2002 | 07:41 PM
91 black convert's Avatar
91 black convert
I have a similar question: Has anyone tried the ADS Superchip?
I don't expect miracles from it, (its only $100), but it says that it will increase the timing, adjust the mixture, change the shift points and delay the converter lock-up. Only under WOT.
This sounds like it will allow you to better use what is already there in your stock 'Vette.
Anyone with experience with one of these? :confused:
Inquiring minds want to know....:seeya
[Modified by 91 black convert, 5:44 PM 3/3/2002]
Old Mar 3, 2002 | 08:06 PM
vette punk's Avatar
vette punk
Default Re: Who got the chip?? (91 black convert)
I have had 3 TPIS chips and have had good results with them so far. Quite expensive though. See http://www.tpis.com
Jim B. :conehead
Old Mar 3, 2002 | 09:48 PM
C4RAG's Avatar
C4RAG
I had a superchip in my last vette and while it did make perfomance increases, I did not like the new shift points and really didn't like the fact that there is just no getting ahold of anyone at ADS... I know, I tried 2 dozen times if not more... The phone is never answered nor were any of my mails or faxes... Given that, you might like it but more importantly, you had better like it because you will never be able to return or ask about it...
To Who got the chip??
