LT1 rocker noise
Old Dec 28, 2009 | 06:17 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default LT1 rocker noise
Iv got a little more noise from the valve train then I like, if I pull the covers off are the rockers adjustable on a 92? Its just a ticking noise.
Old Dec 28, 2009 | 06:25 PM
STL94LT1's Avatar
STL94LT1
Yes, the rockers are adjustable.
Old Dec 28, 2009 | 07:50 PM
dolbnyc's Avatar
dolbnyc
I have a similar noise on my car, it turns out that it is an exhaust manifold leak, not the gasket but the manifold has a hole in it.
So I will be buying headers. Just mentioned it because I thought it was something under the valve cover too. Check that too just incase u never know.
Old Dec 28, 2009 | 07:52 PM
STL94LT1's Avatar
STL94LT1
Also check the injectors, they are noisy on these cars.
Old Dec 28, 2009 | 08:10 PM
kimmer's Avatar
kimmer
Thanks guys, I did use a stethescope and it is comming from under the valve cover.
To LT1 rocker noise
