suspension rebuild.
Old Dec 29, 2009 | 07:07 PM
simple green's Avatar
simple green
Default suspension rebuild.
I'd like to start redoing my Motor/Trans mounts, steering/suspension bushings, ball joints, shocks etc.. For my 94's (non FX4) 180 monthly extended work period refit. I'd rather keep it all rubber, because I'm afraid it will get squeeky and rigid if I go with Poly. I'd like to keep it stock like if possible. Problem is, I don't know where to get the stuff besides the dealer. Also what shocks to get. I read the sticky on suspension rebuild, and although it has lots of great tips, it was all polyurethane parts. Has anyone else gone through this?
Old Dec 29, 2009 | 10:11 PM
aboatguy's Avatar
aboatguy
Only replacement suspension bushings are poly. I did a full poly install back in late 05 and still no squeeks (recently replaced the dog bones with a rod end trailing arms)
I'd do polys again in a heart beat but if you want OEM rubber check out corvette recycling they have NOS suspension components for a resonable price http://www.corvetterecycling.com/category_s/23.htm
Old Dec 30, 2009 | 12:42 PM
simple green
Thanks boat guy.
Is there anywhere that sells bushing kits, so that I'm not buying the whole control arms? etc..
Old Dec 30, 2009 | 01:27 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
wish there was
poly is not allowed in stock classes
so people wind up buying the entire piece.
Old Dec 30, 2009 | 04:04 PM
simple green
Really? nobody makes stock suspension soft good replacements? Not that corvette recylings prices are out of line, but I don't need new A-arms...
Has anyone priced them from GM? or are they not available?
Old Dec 30, 2009 | 04:53 PM
aboatguy's Avatar
aboatguy
Really no one makes rubber suspension bushings I said in my first post if you want new bushings poly. Poly is is not the only option just the most mellow....you can get poly ..... delalum .....rod ends....
If you want rubber the GM sold replacement suspension components. and cheapest new rubber components I've seen are in the link I posted
Good luck
Mike
To suspension rebuild.
