I removed the air pump on my '89 yesterday and installed the Breathless pully,
I also remove the diverter valve and all of the plumbing, my questions are as follows:
1. What do a I do with the two plugs that go to the diverter valve?
2. Will unpluging and stowing these plugs cause a problem with the ECM, i.e. set any codes?
Currently I have stowed the plugs out of harms way.
Remove all A.I.R. system components...use the rubber "caps" on the exhaust manifold tubes. I didn't set any codes with the wiring harness "dangling free."
