700R to a TH350
Old Jan 6, 2010 | 09:25 AM
NXS's Avatar
NXS
I've ridden in 8 and 9 second rides on the street, surely they rpm quicker...
and your car should not act like it is much lower than a th350 with 4.11 gears
Old Jan 6, 2010 | 12:41 PM
96z51's Avatar
96z51
Originally Posted by rodj
3.73 gears and 3500 stall spins up real fast
Will be interested to see your opinion once you own one
well i have owned a 4l60e that had a 4000 stall and 3.23 gears and some how i could shift it correctly. so i don't understand how you are having such an issue.
Old Jan 6, 2010 | 01:08 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by Bob86ZZ4
Going to build it with a manual valve body? Then you don't need to worry about the vacume kickdown and such. For drag racing I'd use a reverse pattern manual valve body. It won't provide you any engine braking tho when lifting so not good for autocross or road racing.
Hey TCI makes a manual VB with and without engine braking.
For fast shifting you can use an electronic or CO2 air shifter with RPM switch.
Old Jan 6, 2010 | 05:26 PM
rodj's Avatar
rodj
As Pete K noted earlier, PATC have a 2.84 1st gear conversion for the T700 that is showing .2-.3 ET improvement with the gear swap only due to less rpm drop on the 1 - 2 shift. The reduced 1st gear ratio also helps with spin off the line in high Hp apps
Old Jan 6, 2010 | 05:54 PM
383vett's Avatar
383vett
I use a 4L60E with a 4.33 rearend. Talk about a quick shift. Launches are 1.40 60' and very consistant 10.60 runs. Because it is computer controlled, I just leave the shifter in drive and let the car win the race.
Old Jan 7, 2010 | 06:36 AM
93 ragtop's Avatar
93 ragtop
Originally Posted by frank j galus
Want to change my 700 to a 350 in my 86 vette. Does anyone know where I can get the spacer or have a diagram so I can have it made locally. Thanks
Frank, look at this post. http://forums.corvetteforum.com/c4-t...r-the-guy.html
Go to the 10th response and a guy list the place to buy the adapter I believe you are asking for.
Good luck, and let us know how it turns out.
Old Jan 14, 2010 | 02:10 AM
fast383vette's Avatar
fast383vette
i just got a 350 with a th400 for 800$...dieing to drop it into my 87 vette auto just want to know who makes the kit for the 400 intall.....dont want to fab a c mount
Old Jan 14, 2010 | 06:00 AM
93 ragtop's Avatar
93 ragtop
You may want to start a new thread on that, so you may get more responses.
But I suspect the 400 will require alot more mods to make fit. For openers, how close is the length to the orig. transmission. Will exhaust clear the transmission? Again, I have no experience with that conversion, but I do suspect alot more work then would be with the 350 transmission.
Old Jan 14, 2010 | 08:37 AM
rodj's Avatar
rodj
I believe you will be on your own there , not a popular swap so doubt you will find a kit.
Several have done it in the past ; short shaft TH400 is shorter than T700 .28 3/8 " vs 29 7/8" for Vette T700
