Advise Needed on LT1 Intake conversion
Old Feb 4, 2010 | 02:09 PM
  #41
DaNewmanator's Avatar
DaNewmanator
Default Thank you!
Originally Posted by rodj
Somebody elses nice pics.I used same dist on my HSR.
Mike at www.eficonnection.com ( amounst others) does a adapter harness ($15) to connect from the big HEI harness connector to the small F-Body type dist so no cut / splice needed and your wiring stays stock.
You also need the 2 wire coil pigtail ($10) to connect your remote mount coil
See
http://www.eficonnection.com/eficonn..._pigtails.aspx
I just got off the Phone with Mike at EFIConnection and he is sending everything I need... Woot! Great transaction and a good guy to talk to. Highly reccomended if you need the pigtails.
Thanks again rodj!
