Need help jacking rear for u-joint replacement!
Old Jan 8, 2010 | 11:22 AM
tnz5106's Avatar
tnz5106
Default Need help jacking rear for u-joint replacement!
Hey C4 brothers, I have my '86 up on my quiklift and I was trying to jack the rear tires off the lift so I can remove the half shafts to replace the u-joints. I started out using a 6 ton jack on the jack support that the quiklift has(see photo) but the rear of the car wanted to move over because I was off center on the carrier. So I put a floor jack with a 4x4 block approximate 18" long and tried to use that along with the 6 ton. I placed the 4x4 between the 2 exhaust pipes right in the center of the fiberglass leaf springs. But as soon as the tires started coming off the lift the car wanted to move again. I made sure that everything was centered the best I could but I don't feel safe with this method.
Has anybody ever attempted to lift the rear while the car is on a quiklift? I have attached a couple of photos that will hopefully give you an idea of my sitiuation...........thanks
http://i155.photobucket.com/albums/s...6/100_2211.jpg
http://i155.photobucket.com/albums/s...6/100_2212.jpg
http://i155.photobucket.com/albums/s...6/100_2213.jpg
Old Jan 8, 2010 | 11:31 AM
StealthLT4's Avatar
StealthLT4
You copied the "..." of the URL in your links...we need the whole link to see it!
Old Jan 8, 2010 | 11:55 AM
jhammons01's Avatar
jhammons01
Just use the pinched part of the frame in front of your rear tires.
Jack up one side, and not that I recommend this.....but I use the lower Shock mount and lift one side and place a jack stand under the pinched part of the frame.....then go to the other side and repeat.
Not sure what you mean by the car is moving.....
Old Jan 8, 2010 | 02:04 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
You will probably thank me later - remove the exhaust from behind the cat back.
Find a good flat spot on the diff to jack up the rear from the quicklift.
Use jackstands to support the car.
Old Jan 8, 2010 | 02:45 PM
jhammons01's Avatar
jhammons01
^^You know, I started to do that...in order to get the D36 out this time without dropping the whole exhaust.....but those four bolts were stuck solid......solid I tell ya....
I am going to my exhaust shop to get those things broken loose and then put some anti-seize on them
Old Jan 8, 2010 | 04:32 PM
DVNCI's Avatar
DVNCI
Would this help?
http://www.corvettegadgetman.com/products3.html
Old Jan 8, 2010 | 04:51 PM
tnz5106's Avatar
tnz5106
Originally Posted by RUKWKR
That is pretty much what I was doing with the 4x4 except thats probably more stable. The feedback I am getting though is to lift 1 side at a time by jacking on the lifting points that I am still not sure were they are at. I will look in my owners manual and a shop maual I have..................thanks
Old Jan 8, 2010 | 04:54 PM
tnz5106's Avatar
tnz5106
Do you have a picture? I don't see a frame, its enclosed isn't it?
Old Jan 8, 2010 | 05:00 PM
94vettelover2's Avatar
94vettelover2
If he does buy that,make sure you get your cut
Old Jan 8, 2010 | 05:39 PM
jhammons01's Avatar
jhammons01
That doesn't always work, the exhaust has a gusset welded between the two pipes where that should go.
I was going to go down to industrial supply and get a rem of H stock and make one.....but again until I go see my Muffler shop..that gadget will do no good
The Frame that I am referring to is right next to where your Rocker panels end and the underside start.
You'll see where SMC stops and Metal starts.......then the frame turns inward toward the differential...that's the spot....it is not a nice flat area....it is a thin piece of metal or a rail if you will.
Old May 8, 2010 | 05:11 PM
samsonb's Avatar
samsonb
I know to put the jack stands on the pinch welds in front of the rear tires. But does anyone know of where else you can put the jack other than the stock jacking points?
My stock jacking points gets a couple a gashes in it from my jack. Next time, I may just try putting a block of wood on top of the jack to see if that help with it denting in the stock jacking point.
Old May 10, 2010 | 02:11 PM
jerryg01's Avatar
jerryg01
Get a couple used hockey pucks and put them on the table on your jack, and you won't damage your jacking points.
Old May 10, 2010 | 02:29 PM
samsonb's Avatar
samsonb
What about a piece of wood? I've heard people having problems with the hockey pucks cracking on them.
I'm trying to jack the rear so I can put the car in neutral to check half shaft U joints and hubs.
To Need help jacking rear for u-joint replacement!
