Electrical issue
Old Jan 9, 2010 | 11:58 AM
gtspeed98's Avatar
gtspeed98
4th Gear
Default Electrical issue
'95 coupe auto. While driving "SYS" will flash three times then go back to mpg readout. Owners manual states "may be a problem with your electrical system" It seems to drive fine. Recently changed OEM stereo to aftermarket using wiring harness from Crutchfield. The cruise control was not engaging last time I drove the car.
I was going to un hook stereo first, then check connections for cruse control. Any other areas to check when it warms up a bit.
GTSpeed98
Old Jan 9, 2010 | 05:47 PM
rodj's Avatar
rodj
Did you install resistors on the stereo lighting circuit?
If not SYS will flash because system is looking for circuits that are not there with aftermarket setups
http://www.corvetteforum.net/c4/dave8476/index4.shtml
Old Jan 10, 2010 | 10:39 AM
gtspeed98's Avatar
gtspeed98
4th Gear
Thank youfor your quick response. No I didn't. Do I put it inline on the wire for lighting and what value resistor? When I bought the wire harness and antenna extension from Crutchfield nothing was mentioned about the resistor.
Old Jan 12, 2010 | 08:29 PM
gtspeed98's Avatar
gtspeed98
4th Gear
Looked through bulletin, noticed the it relatetes to '90 - '93 with electronic air which pertains to my '92. My '95 has manual air. The aftermarket radio has a circuit board no wires.
Old Jan 12, 2010 | 11:21 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...sys-light.html
http://forums.corvetteforum.com/1559553067-post3.html
To Electrical issue
