Interior lights flash when hitting stiff bump......
Old Jan 11, 2010 | 09:10 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Default Interior lights flash when hitting stiff bump......
Interior lights flash on and then off quickly when hitting a stiff bump what could this be on my 93 Vert?
Old Jan 11, 2010 | 10:29 AM
3D-Aircrew's Avatar
3D-Aircrew
Default Suspect one of the door hinge switches
Likely going bad. There are several threads on how to test and change them out ... try a search.
Old Jan 11, 2010 | 01:27 PM
murray59's Avatar
murray59
Just a guess but could it be a bad door switch?
Old Jan 11, 2010 | 02:18 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
It's a door switch adjustment. If it's like my '89, the switch isn't the one by the hinges (like normal cars). It's the switch at the back of (one of) the door(s).
Changes in weatherstripping and/or the roof being out can increase the chances of the switch losing contact. When it loses contact for a sec, the lights come on.
Seems like there was an adjustment (or I added a shim) to fix the problem.
Old Jan 11, 2010 | 02:47 PM
94vettelover2's Avatar
94vettelover2
Old Jan 11, 2010 | 09:30 PM
ks5shooter's Avatar
ks5shooter
thanks
Old Jan 11, 2010 | 10:48 PM
jimg's'93's Avatar
jimg's'93
I'd say that's it as well.
Old Jan 11, 2010 | 11:16 PM
M. Schumacher's Avatar
M. Schumacher
The tip of the switch wears down over time.
Old Jan 12, 2010 | 08:31 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like your door ajar switches have gone ****-up. Mine did the same thing. Tell me, is your alarm horn sounding randomly, too, when the car's parked? That's another sure-fire sign. It's an easy fix. I believe the switches run about $15 bones each at the dealer and the FSM details how to swap them out.
To Interior lights flash when hitting stiff bump......
