IAC question
Old Jan 11, 2010 | 01:37 PM
HdRider04's Avatar
HdRider04
Default IAC question
I am having problems with the motor surging when at a idle... I have been reading posts all morning and I am going to check for vacuum leaks and the IAC tonight.
My question is can the IAC be removed and cleaned w/o removing the TB? 1986 stock
Old Jan 11, 2010 | 01:56 PM
WW7's Avatar
WW7
Yes and no. Yes the IAC can be taken out and cleaned but to do it right the whole unit needs to be cleaned. There are passages that the air flows through that will have gunk in them that should be cleaned with carb or TB cleaner, and taking off the TB will also allow you to clean the carbon off the back of the TB and out of the plenum..You will also need to replace the 3 gaskets for the TB and the IAC gasket.Just clean everything up and put it back together, only takes about a hour to do..WW
Old Jan 11, 2010 | 02:57 PM
94vettelover2's Avatar
94vettelover2
If you do this just replace IAC if you do not know the age or last time it was replaced.I don't want to sound like a broken record but our cars are getting old & if parts are old,possibly original & suspect just replace as these parts may be near end of there useful life.I'm not saying replace every part but if part is original & suspect-replace it
Old Jan 11, 2010 | 07:25 PM
Tom 35th anniversary's Avatar
I agree, replace it...I tried to clean mine but still surged. Took whole throttle body off, and put on new IAC. Now idles smooth and surge is gone. A big noticable difference.
Old Jan 13, 2010 | 02:02 PM
turbotim23's Avatar
turbotim23
make sure you check the throttle shaft for extra play. Sometimes they can be worn and leak around it. When I checked my 93 for vacume leaks I found a lot of the hoses were brittle from heat and would leave black on your hands when you touched them.Also some of the hoses were kind of hidden, mostly by battery area. Way past time to replace them. It ran so bad I thought I needed to replace injectors but after replacing hoses it smoothed right out. Good Luck Tim
Old Jan 13, 2010 | 05:35 PM
SteelBlue91's Avatar
SteelBlue91
For you guys that replaced yours, what brand/vendor did you get your new valve from? I have had mine out (just the valve, without removing the throttle body) and cleaned the passageway. This helped a lot, but I think the cold weather is making it stick or something. Sometimes it idles great, but sometimes not (and never when it is stone cold).
SB91
Old Jan 14, 2010 | 01:34 PM
aklim's Avatar
aklim
I have replaced mine with the GM one.
Old Jan 14, 2010 | 01:45 PM
vettef6's Avatar
vettef6
I bought mine from RockAuto.
Tried cleaning and adjusting the pintle quite a few times, but the IAC still didn't work properly. BUY A NEW ONE!!!!!
Old Jan 14, 2010 | 01:50 PM
aklim's Avatar
aklim
Clean the whole TB first before buying a new one or it might work well for a bit and then stop working well. Ask me how I know.
clean the ENTIRE thing. That means take apart the IAC housing and all the passages. Then reset it so that the IAC counts area bout 15-20 and the TPS is right. At that point, you can determine if it is the IAC or not.
Old Jan 14, 2010 | 05:31 PM
Grumpy_TWB's Avatar
Grumpy_TWB
St. Jude Donor '09-'10
SB91
Napa
Old Jan 14, 2010 | 06:54 PM
SteelBlue91
Yea, I was planning on doing this when the weather gets where my fingers aren't going numb from the cold. I had previously just pulled the valve and cleaned out the valve area, but I realized that I can't get the backside clean without removing the whole TB. Just having the valve tip being clean helps, but it was pretty bad and I figure the rest is not helping.
Old Jan 15, 2010 | 03:52 PM
aklim's Avatar
aklim
WTF? You are a Gander Mountain Employee whose slogan is "We live outside"???
Take the 3 cables off and 4 bolts. Loosen 2 clamps and you can take the heater hose off. Put in a bypass pipe while you are at it.
Take the TB inside.
To IAC question
