The Teardown Continues...
Old Jan 11, 2010 | 08:57 PM
kangi's Avatar
kangi
Default The Teardown Continues...
Well I spent some more time on the '84 tearing down the engine compartment. I am amazed how dirty it is in there, gonna have to give the whole engine compartment a liberal spritzing of simple green. Maybe I'll be a little more eager to show it off once I spruce it up a little bit
Went pretty well pulled the power steering pump:
Pulled the AC pump and condensor:
And finally got the lid off the intake:
I'm thinking next time I ought to be able to get the water pump, and the intake...maybe the heads if I feel ambitious
Old Jan 11, 2010 | 09:22 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Will be worth it
Old Jan 11, 2010 | 10:56 PM
ant-knee470's Avatar
ant-knee470
What are you going to do it?
Ant...
Old Jan 11, 2010 | 11:11 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
too bad your not closer, for $1200, I have a rebuilt 4 bolt main 350 with a mild cam that would make that thing purr.
Old Jan 11, 2010 | 11:30 PM
kangi's Avatar
kangi
Ant...
I'm just going through the top end. I've ported a set of '113 heads and ported out a spare crossfire intake, so I'll be installing those. I also plan to put some 1.6 roller rockers and a shiny new comp cams retro roller cam in there, I'm looking at the XFI 268 grind. Some long tube headers and dual exhaust to finish it off. I'll also be doing some general clean up as well.
Old Jan 11, 2010 | 11:39 PM
ant-knee470
Hmmm,
I have the same setup, I was thinking of porting the intake as well, I have heard
it would make a big difference, If I just do the intake, Would I notice a difference in the performance or would I have to do the heads as well? I am looking for a set of the shorty headers right now as I have the exhaust off my car..
Ant....
Old Jan 12, 2010 | 12:07 AM
kangi's Avatar
kangi
Hmmm,
Ant....
This was one of those snowball projects. Started with just wanting to port the intake to free up a few ponies. Then I figured well might want to throw some headers on there to help it breathe, of course if you want to breathe better you need better heads, then cam and yada yada yada here I am. So to answer your question, no I don't think you need to do the heads, but every little bit helps.
I haven't got a lot of experience in this porting business but I've done enough research to be pretty confident in doing it myself. I'm happy to share what I learn as I go. So good luck with your own ride!
Old Jan 12, 2010 | 05:51 PM
kangi's Avatar
kangi
Default Tues. update
Another few hours in the shop today. Got my water pump, distributor, and intake manifold removed.
Heres some pics:
Heres why this whole thing started, notice how small the ports are in the intake manifold
Heads tomorrow
Old Jan 12, 2010 | 06:31 PM
ant-knee470
Man looking at your pictures makes me want to do mine, Just $$$ tight right now, But soon, Very soon... Nice pictures keep them coming..
Man I was looking at the manifold, Theres alot beef that can come off that sucker.
Are you doing the bore yourself?
Ant,,,,
Old Jan 12, 2010 | 06:36 PM
kangi's Avatar
kangi
Ant,,,,
Yeah, I have a thread here somewhere with pics of the intake port job. I've been savin' $$ since I bought this thing, still sucks to spend a lot...
Old Jan 13, 2010 | 07:14 PM
kangi's Avatar
kangi
Default Wed. update
Got the exhaust manifolds and heads off today:
Well thats it for Wednesday, I'll see what I can do tomorrow
Old Jan 13, 2010 | 07:50 PM
Pete K's Avatar
Pete K
Is that a stroker motor? Pistons look like my KB 135's.
Old Jan 13, 2010 | 08:02 PM
ant-knee470
Looking good man,
Are you doing rings & bearings to?
I would think you would have too.. I have heard lots of stories when peeps do the top end & not the lower & does'nt last long..
ALso what kind of work you doing to the heads?
Ant....
Old Jan 13, 2010 | 08:23 PM
kangi's Avatar
kangi
Nope, its a stock L83
Looking good man,
Ant....
I haven't heard anything like that, I'm just doing the top end. The heads are getting new valves, springs, seals, and a pocket port and polish.
Old Jan 13, 2010 | 08:25 PM
Pete K's Avatar
Pete K
Musta been overhauled I guess. Pistons don't look stock.
Old Jan 13, 2010 | 10:27 PM
kangi's Avatar
kangi
I don't know Pete, I've heard these pistons are supposed to have the trough, as opposed to the valve depressions, if that's what you're referring to. But I've never had this thing apart before so I really don't know.
Old Jan 13, 2010 | 10:30 PM
pologreen1's Avatar
pologreen1
this
http://forums.corvetteforum.com/c4-t...-critique.html
Old Jan 13, 2010 | 10:35 PM
kangi's Avatar
kangi
Originally Posted by pologreen1
That's the one
To The Teardown Continues...
