when going over to an atuomatic are the bolt to the bellhousing longer or shorter
RichS says I need different ones, so the ones that came on the automatic car is the corecct ones correct? and do not reuse the manual ones correct?
what is the difference?
unless your car came with different bolts then mine with a zf6 then they should be plenty long enough for the bellhousing to the engine. now the flywheel to crank bolts for a dual mass are longer then the autos flexplate bolts in which you would need to get new bolts
