LT1 Underdrive pulleys - Charging problems, or do they work good?
Old Mar 5, 2002 | 12:59 AM
thmupr's Avatar
thmupr
Default LT1 Underdrive pulleys - Charging problems, or do they work good?
Thinking of installing underdrive pulleys, and would like some input from people who have them. Does your alternator still charge good at idle? Also, which brands are better? Thanks in advance.. :cheers: :flag :cheers: :cool:
Old Mar 5, 2002 | 01:12 AM
vader86's Avatar
vader86
Default Re: LT1 Underdrive pulleys - Charging problems, or do they work good? (thmupr)
Ive heard of some people having charge problems, personally i wouldnt bother with them.
Old Mar 5, 2002 | 04:47 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have the March underdrive crank installed. It comes as a 3-piece set but I haven't installed the alternator overdrive nor the water pump overdrive pullies.
At idle with winter accessories On it gives about 12Vdc at idle; by 900rpm or so it's up to the normal 13.5Vdc.
Old Mar 5, 2002 | 08:46 AM
Rob90's Avatar
Rob90
Default Re: LT1 Underdrive pulleys - Charging problems, or do they work good? (65Z01)
I have the March AMP series. No problems with charging. They make a set called Power series that may cause problems
To LT1 Underdrive pulleys - Charging problems, or do they work good?
