Open Loop Problem?
Old Jan 17, 2010 | 07:07 PM
xole's Avatar
xole
Default Open Loop Problem?
Gang,
Looking for some guidance on what appears to be an open loop issue. The car stumbles when torque is applied. This occurs either when cold or for the first few minutes after it is started when at operating temperature. Idle and starting are fine.
It is a pretty much a stock 94 LT1 w/103K. I have done a lot of basic maintenance to it which has fixed a lot of my other problems including plugs, wires, tps, filters, injectors, etc. The opti was supposedly just replaced by the PO but who knows.
I am still working on mastering the FSM (a LOT of info there).
There are no codes (paper clip method), passes emissions fine.
Any suggestions? I was thinking of picking up the oddball cable to do some data logging on it but have not pulled the trigger yet on that.
Thanks!
-David
Old Jan 17, 2010 | 10:19 PM
Al Borman's Avatar
Al Borman
So you are saying that once the engine is warmed up that it runs fine, right ?
If this is truely only an "open loop" problem, then the 2 main inputs used by the PCM for AFR is your MAF and MAP sensor. These are the only sensor input used by your PCM during "open" loop to derive a ballpark air to fuel mix of 14.7:1
Maybe your MAF or MAP sensor is flakey and only shows up during open loop. During closed loop, the feedback from your O2 sensors may be enough to compensate for the faulty or flakey sensor....
Anyway, I would test the MAP sensor first, then the MAF.
Old Jan 18, 2010 | 12:06 AM
redrose's Avatar
redrose
nope..coolant temp sensor is critical for 'cold start' and 'cold drive-away'...many are 'off calibration' but no code will display...check cold and at operating temp using scanner or DVOM/compare with chart in Serv Manual before replacing
Old Jan 18, 2010 | 09:43 AM
WW7's Avatar
WW7
This is probably going to need a scanner hooked up to figure it out..WW
Old Jan 18, 2010 | 01:23 PM
Al Borman's Avatar
Al Borman
uhhhh..... "nope" to what ? There are more input parameters to the PCM than just the CTS during cold start.
On a cold startup, disconnect your MAF and the engine will stop. Disconnect your MAP and you will hear a discernable change in idle. These actions will however set error codes. But the OP's problem is a very subtle one, and I do agree that a scan tool is his bet bet on identifying the problem.
-Al
Old Jan 18, 2010 | 06:45 PM
xole's Avatar
xole
Thanks everyone for the suggestions. Looks like a scan tool is in my future.
To answer the questions, yes, she runs great warm. It does have the problem when warm if i turn off the car and then start it again. It was my understanding that it would be in open loop in that situation as well which is what is making me look at open loop issues.
I will update folks once I get more info.
-D
To Open Loop Problem?
