Re: Brake Problem 1987 C4
Old Jan 21, 2010 | 04:18 PM
railer75's Avatar
railer75
Default Re: Brake Problem 1987 C4
Thanks to all who offered advice! The problem was the ABS unit. It has been replaced and the brakes are back to normal.
Old Feb 2, 2010 | 09:42 PM
J's Nest's Avatar
J's Nest
Default What was your problem?
I have an 87 and the brakes will pulsate when you are sitting with the brakes applied. I have removed the brake fuse for now, but would certainly like to find the problem. I understand the ABS unit can be very expensive so I have been trying to avoid that if possible.
Any information you can provide would be greatly appreciated. My car is tucked away for the winter. We have about 4 feet of snow right now so it will be awhile before I get it.
Thank you
Old Feb 2, 2010 | 10:31 PM
railer75's Avatar
railer75
Check Ebay- I bought a good used abs unit for under $50- There are a lot of sellers who deal in car parts and are reputable-many who specialize in Corvette parts. Good luck
To Re: Brake Problem 1987 C4
