weather striping for 87
Old Jan 21, 2010 | 05:45 PM
lvbg1435's Avatar
lvbg1435
Default weather striping for 87
how hard is it to replace the weather striping on the doors top and hatch
i never replaced that stuff never hade to
Old Jan 21, 2010 | 11:14 PM
Strike3's Avatar
Strike3
My first try at it was on my 87. It is, pretty much, common sense and patiants. I've now also done a 91 and am getting ready to do an 85. Doors are easy due to all the push-fasteners in them.
First, you want to remove all the old stuff and, working with the 3M adhesive remover, clean all surfaces.
The biggest problem arrises from 2 things. 1, rubber stretches. The amount of force you use tugging or puling on it can cause you to be off center. If you have one side glued down and go around to the other side of the car and pull on the strip, sticking it down as you go, you may find you are several inches longer than you need to be, but now you have it glued down in the wrong place. The second problem is that, once it makes contact, if the adhesive is applied per instructions, it's not comming off without damage.
What I have learned to do is trial fit the weather strip onto the car. Place tape on the strip and a matching piece on the car, about every 2 feet. Then draw a lind across both. After you apply the adhesive you can install the weatherstrip, matching up your marks, rather than finding out you've streched the thing too far, too late.
Old Jan 22, 2010 | 11:29 AM
samsonb's Avatar
samsonb
From what I've read with regards to say the windshield weatherstripping. Is your not supposed to glue it down. Just press it in the channels. Then maybe glue down the ends.
To weather striping for 87
