Oil in the Intake Plenum
Old Jan 22, 2010 | 03:31 PM
cumbercr's Avatar
cumbercr
Default Oil in the Intake Plenum
I was removing my Super Ram plenum to replace the EGR temperature sensor. When I removed the lid I found oil in the plenum. The engine has been using more more oil than normal. I also found a vacuum leak where the PCV hose connects to the intake manifold. Any possibility the two are related or should I be looking elsewhere?
Old Jan 22, 2010 | 03:53 PM
2manytoyz's Avatar
2manytoyz
i was going to say pvc valve before i read the last part.Replace the valve with a AC DELCO one!Check your results after that.
Old Jan 22, 2010 | 04:05 PM
surfer92's Avatar
surfer92
Where is the leak?
In the grommet where the PCV valve goes in or from the hose?
Replace either that is leaking, your PCV should be fine, just shake it and if you hear a rattle, it is good.
Also, I think ac delco parts are overrated.
Old Jan 22, 2010 | 04:23 PM
383vett's Avatar
383vett
I have always had oil in the plenum of my SuperRam. I had some when I used to run a pcv valve and still do even though I no longer run a pcv. These manifolds have a great deal of reversion and seem to suck any oil up the runners into the plenum. My motor does not use oil, but there is always a thin film of oil in the plenum. Your excessive oil use may be related to your pcv valve and leak but some oil I think is normal.
Old Jan 22, 2010 | 04:37 PM
cumbercr's Avatar
cumbercr
Originally Posted by surfer92
Where is the leak?
Thanks Surfer. The leak was the hose that connected to a barbed nipple on the manifold. The hose had swelled (wrong heat rating) and was leaking pretty bad. The valve is fine.
Old Jan 22, 2010 | 04:58 PM
cumbercr's Avatar
cumbercr
Its good to know some oil is normal. So is the oil getting past the rings because of high crankcase pressure?
Old Jan 22, 2010 | 05:08 PM
samsonb's Avatar
samsonb
Do you have a hose going from the passenger valve cover to the throttle body like on the L98? That could be where oil is coming in at. Which is PCV related.
Old Jan 22, 2010 | 05:26 PM
cumbercr's Avatar
cumbercr
I do have the hose from the throttle body supplying air to the valve cover. The hose is clean and dry, no oil. The oil has to be coming up the runners.
Old Jan 22, 2010 | 06:06 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I have an extra catch can ...for sale
Old Jan 22, 2010 | 07:13 PM
cumbercr's Avatar
cumbercr
So where does the catch can fit in the system?
Old Jan 22, 2010 | 07:43 PM
ex-x-fire's Avatar
ex-x-fire
Hey, cumbercr are the heads you running got screw in studs for the rockers? You might want to reseal them, I have had alot of intakes off on 2 piece manifolds, not just GMs, I find alittle oil in most of them. Check your intake bolts too.
Old Jan 22, 2010 | 08:10 PM
cumbercr's Avatar
cumbercr
The rocker studs on the intake valves are blind holes. I pulled all the intake studs today just to make sure.
Old Jan 23, 2010 | 12:07 AM
dogfish246's Avatar
dogfish246
Anyone run a catch can on a LT1? Pics?
Old Jan 23, 2010 | 12:27 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
why would you? if your rings and valves seal, you won't need it.
LS engines need it because the piston skirts are so short that the pistons rock at the top of the bore.
Also, they have no individual boring for individual pistons, the logic is, if you cut all the cylinders the same, and the pistons are all the same, everything should fit.......not
To Oil in the Intake Plenum
