A?c problem
Old Jan 24, 2010 | 07:32 PM
wayne smith's Avatar
wayne smith
Default A?c problem
Hi there. I have an 87 auto c68the a/c clutch is cycling every five seconds.I have just replaced the low pressure switch and the blower control module and is full of gas.Any ideas men. Thanks Wayne
Old Jan 24, 2010 | 07:57 PM
TWISTERUP's Avatar
TWISTERUP
That usually means the system is undercharged OR overcharged. If you have AC gauges -what are the pressures?
Old Jan 24, 2010 | 09:06 PM
wayne smith
I have no ac gauges,my guess would be that is overcharged and i will check it out with a aircon guy
Old Jan 24, 2010 | 11:23 PM
Churchkey's Avatar
Churchkey
Remove the connector from the low pressure switch & jump the connector with an opened paper clip. If the compressor runs continuously the system is low on freon. If it still cycles its over charged.
Old Jan 25, 2010 | 12:19 AM
383vett's Avatar
383vett
Gauges are cheap at Kragens. Buy one and a can of c-12 or whatever we're using these days and fill it yourself if it reads low. If high, you're supposed to have it bled at an ac shop that has an evacuator or ...
Old Jan 25, 2010 | 12:30 AM
wayne smith
Hi there.Yes the system runs with the paper clip.and does not get very cold. I had a bloke look at it a month ago and he put some gas in after i replaced the bcm, on doing so he said their was maybe too much head pressure as it cycled every few seconds and told me the low pressure switch was no good and i just replaced it today to find no fix.I will get him back for another try.
Thanks Wayne
Old Jan 25, 2010 | 11:55 AM
SunCr's Avatar
SunCr
Sounds like it's plugged up. Liquid refrigerant is metered into the Evaporator through a fixed, screened restriction called an orifice. When metal or debris (from a worn out compressor or Dryer that's falling apart because it's got the wrong gas in it) gets trapped in the screen, insufficient liquid reaches the Evaporator and what gets in flashes to a gas. That takes the oomph out of it and by the time it reaches the Low Pressure Switch, there's nothing to keep the contacts closed. The clutch circuit then opens and the clutch cycles off. You need to put a Manifold gage set on it and more than likely, take it apart and rebuild it. Don't put any more gas in it as the blockage backs it up creating more pressure on the high side. And if the High Pressure Switch fails, you'll blow a hole in something - like the hood or yourself.
Old Jan 25, 2010 | 07:00 PM
wayne smith
Hi There. From your post this sounds more like the problem. Are you saying to rebuild the compressor and replace the orifice tube or ?. The compressor is three years old i think and has not done a lot maybe a 1000 k. Any info is very much appreciated
Thanks Wayne
Old Jan 26, 2010 | 11:35 AM
SunCr's Avatar
SunCr
Confirm that it's plugged up first, but if the compressor was replaced because the old one seized, that's a good possibility; particularly if all the debris wasn't removed at the time of the replacement.. Assuming it is plugged up, the orifice can be cleaned or replaced. Replace the Accumulator. Flush all lines, Evaporator and Condensor with an appropriate flushing agent and/or consider replacing the Condensor because it's difficult to get all the crap out of it. Flush the compressor by draining any oil that's in it and putting in 4 ozs of whatever oil is compatible with the gas you are using. Turn the shaft a dozen or so times in one direction, then the other. Drain and repeat. Leave 4 ozs of oil in it. Put 4 ozs of oil in a new Accumulator and make sure the Accumulator is compatible with your gas. Pull a vacuum and recharge.
To A?c problem
