need to get a new key need help
Old Jan 26, 2010 | 02:58 PM
Powersmokin's Avatar
Powersmokin
Default need to get a new key need help
I found this chart and when I test my key I'm getting any where from 7.48 and 7.52. what key code would you say that falls under? Thanks for any help
(Pellet Code) (Nominal) (Low) (High)
1 402 386 438
2 523 502 564
3 681 654 728
4 887 852 942
5 1130 1085 1195
6 1470 1411 1549
7 1870 1795 1965
8 2370 2275 2485
9 3010 2890 3150
10 3740 3590 3910
11 4750 4560 4960
12 6040 5798 6302
13 7500 7200 7820
14 9530 9149 9931
15 11800 11328 12292
Old Jan 26, 2010 | 03:06 PM
Churchkey's Avatar
Churchkey
IMHO its #13.
If your checking your key with a digital VOM try a different ohm setting for corresponding results.
Old Jan 26, 2010 | 08:24 PM
dogfish246's Avatar
dogfish246
What setting did you have your meter on??? 100, 1000, 10000??? I would say #13 also!
Old Jan 26, 2010 | 09:11 PM
WVZR-1's Avatar
WVZR-1
I'd tend to agree with the posted results but to "confirm" your VATS ID just take the key to a GM dealer and ask that they "drop" the key in a VATS Interrogator for you to confirm! The parts department will either have the equipment or will have access to it!
Explain why you feel you need a new key? Just a 2nd key or do you have a situation with needing a cylinder etc?
Old Jan 26, 2010 | 09:26 PM
xole's Avatar
xole
I was surprised that even my local Ace hardware had a VATS interrogator (glorified Ohm meter) and blanks with all the different pellets.
To need to get a new key need help
