gear oil and additive???
Old Jan 27, 2010 | 01:05 AM
herman8tr's Avatar
herman8tr
Default gear oil and additive???
I'm almost finished replacing my 2.59 rear with a 3.07 out of my 1990 L98
I now need to know what kind, and how much gear oil, and additive I need to use.
Any details and specifics are greatly appreciated.
Thanks!!!
Jeffrey
Old Jan 27, 2010 | 05:04 AM
Weav's Vet's Avatar
Weav's Vet
Put 2 bottles of limited slip in there first. I got mine at the dealer. Then finish filling it with a good quality SAE 80-90wt GL5 gear oil.
Old Jan 27, 2010 | 07:07 AM
Strick's Avatar
Strick
I agree, 2 bottles of additive and I used GMs dif oil. I bought it all at the dealership.
Old Jan 27, 2010 | 03:01 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I used Penzoil 'GearPlus', which has the LS additive in it already.
Old Jan 27, 2010 | 03:10 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I use Amsoil severe gear oil which has the additive in it already.
Edit: Putting Amsoil in my engine, trans, and diff I picked up 2 MPG on the highway.
Old Jan 28, 2010 | 08:26 AM
herman8tr's Avatar
herman8tr
Thanks for your help guys!!!!!
****ironically, it's incredible how friggin little the Chevy dealer knows about anything!!!!
Old Jan 28, 2010 | 08:38 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL makes several gear lubes, but this is the one I use in my 02 Z06 on the track and would recommend:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
Note that as mentioned above, this fluid does come with friction modifier in it and most do not need extra modifier to prevent diff chatter.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 28, 2010 | 08:45 PM
tblt44's Avatar
tblt44
I just read my manuall and it calls for 4 oz. of the limited slip modifier with a diff change. 80W-90 weight gear oil.
I used valvoline synthetic blend.
this was out of the 95 manuall,should be the same.
I think 1 bottle is 4 oz.
The modifier should be 2 - 6 % of the total fluid change
I bottle is more than enough
Old Jan 29, 2010 | 09:59 AM
techvette's Avatar
techvette
2 bottles GM LSD additive (as suggested by Gordon Killebrew) and filled the rest of the way with GM gear oil.
Old Jan 29, 2010 | 07:50 PM
Strick's Avatar
Strick
That's exactly what he told me.
Old Jan 30, 2010 | 09:59 AM
C66 Racing's Avatar
C66 Racing
Keep in mind that many gear lubes, such as the AMSOIL Severe Gear 75w90 mentioned above, already come with friction modifier in them, so if you had more modifier without knowing this you are losing performance. Not sure of the specific details of the diffs for the C4, but for my 02 Z06, the limited slip diff is designed to pass 75 ft-lb of torque to the wheel with grip. If you add too much modifier, the diff clutch plates will not hold that much torque and you are lowering the capability of your diff to pass torque to the tire with grip. Ideally, you want just enough modifer to prevent chatter and no more. FYI, you can check how much torque your diff is passing to the tire with torque by lifting one rear tire off the ground and with the car in neutral and parking brake off putting a torque wrench on the axle nut. Mine will break at just over 75 ft-lbs of torque - thus performing as designed. If it breaks at less than you expect, you diff is more limited slip than intended. However, most will probably never notice this on the street. On the track, particularly coming out of sharp low speed corners, it will impact you a lot as too much torque will go to the inner unweighted tire and be wasted.
Old Jan 30, 2010 | 10:32 AM
Aardwolf's Avatar
Aardwolf
I do not add more modifier since I buy lube with it included. Last time I tested the diff like mentioned above I saw 110 ft/lbs on the torque wrench.
To gear oil and additive???
