Need Help Please 1994 C4 Idle Issue
High idle is caused many times by vacuum leaks. Could even be an intake leak.I would also get it away from those clowns and find someone who can work on a C4. Check with the local vette club in your area if there are any.
This place is throwing parts at your car and not properly diagnosing it.
http://forums.corvetteforum.com/search.php
go to the search engine on the forum in the key words type high idle and then go down to bottom right and highlight the C4 section (this tells the search engine where to search)
and start reading threads. I and many others have spent hours reading these things and sometimes the answer is found there. There are many who don't come back and tell us what fixed their problem so every thread doesn't have the answer, you just have to keep hunting and pecking until you see something that was a cure with your symptoms. that doesn't always fix your particular situation but it gives you more knowledge than the mechs at the dealership seem to have.
Also remember to come back and start another thread that, or add to this one, and tell us what the fix was. I was looking at several old threads today that discussed your problem and there were several different cures. So best of luck and don't be afraid to come back and ask more questions. I am not an expert but there are many here who are and you just have to catch them on line.
I have an issue I am working on myself but I am reluctant to send it to the dealer to be diagnosed by people who probably have little to no experience with these things.
And buy yourself an FSM if you don't already have one. And take your wife to dinner and tell her we will get this thing fixed.
when you type the words in the search engine and select the C4 target area and hit enter it will pull up something like this
http://forums.corvetteforum.com/sear...rchid=14558600
see, you are on the front row!One more thought. I read a thread today that a member was trying to tell the OP what to fix and he didn't listen. About 1k later he did and kablam! problem fixed. So listen to these guys and be patient on catching them on line.
