wheel studs??
Old Mar 6, 2002 | 12:27 PM
Gogobig92's Avatar
Gogobig92
Default wheel studs??
Anyone know what size studs you need, when changing to longer ones for drag racing. I need to change mine on my 92,because of the weld wheels they are not going to pass tech, they have to stick through the lug nuts. I also need to know how hard they are to do on these cars. thanks
Old Mar 11, 2002 | 07:45 PM
Corvette_Z51's Avatar
Corvette_Z51
Default Re: wheel studs?? (Gogobig92)
ARP sells Metric wheel studs, 12MM, 1.5pitch, 2 1/2" long part# 100-7708.
:yesnod:
Can also get some from Doug Rippie or Lingenfelter.
Not hard, just don't bend the wheel bearing assembly with a hammer! Use an old lug nut and plenty of anti-sieze to install the new ones.
[Modified by Corvette_Z51, 6:47 PM 3/11/2002]
Old Mar 11, 2002 | 07:58 PM
555ciC4's Avatar
555ciC4
NHRA requires that the stud enter the nut the width of the stud, a 12mm only has to be inside the nut 12MM. A 1/2 stud in the nut a 1/2. Rules changed. Hate to see you send money and do all that work for not. :D
Page 216 2002 NHRA Rulebook. :cheers:
[Modified by 555ciC4, 12:01 AM 3/12/2002]
Old Mar 11, 2002 | 08:03 PM
J Z06's Avatar
J Z06
Default Re: wheel studs?? (555ciC4)
555cic4 HOLY SMOKES what an engine? Do you know Bill C and wheelsup? they're from your neck of the woods! Impressive car.
Old Mar 11, 2002 | 08:04 PM
Corvette_Z51
I hope you're not racing that BadBoy 555ci Monster with just 12mm contacting each nut. If so, that's nuts! :crazy:
Old Mar 11, 2002 | 08:06 PM
555ciC4's Avatar
555ciC4
Default Re: wheel studs?? (Corvette_Z51)
12mm in front and 1/2 in rear. And just for the record I am nuts. :crazy:
Old Mar 11, 2002 | 08:15 PM
555ciC4's Avatar
555ciC4
Default Re: wheel studs?? (JD 90 383)
I know Bill and Phil(wheelsup) we talk every month or so. Phil and I were going to attend a chassis class together a couple weeks ago. But it was cancelled. Bill has a Stage II LPE C5 with a boost ****. Phil's car is very impressive, 10's from a stock 350! :D
Old Mar 11, 2002 | 08:17 PM
J Z06's Avatar
J Z06
Yep, those are class "A" Guys. With even nastier cars! It would be nice for all of your crew to caravan up for the corvette challenge! I don't think we have many cars of your e.t. range which would make it all the better!
Take care.............JD :cheers: :cheers:
Old Mar 11, 2002 | 08:43 PM
Bill C's Avatar
Bill C
This looks like a perfect time to chime in. Have watched him race for many years and I can certify that he is nuts,crazy,insane, cracked, crazed, cuckoo, daffy, demented, deranged, disordered, distraught, lunatic, screwy, unbalanced, unsound, wacky, foolish, ect,ect....Sorry could not resist.
Bill :lol:
Old Mar 11, 2002 | 08:53 PM
555ciC4's Avatar
555ciC4
Default Re: wheel studs?? (Bill C)
Hi Bill! :D Thanks for chiming in.:lol: Nice to hear from you. :) I'll call you at work tomorrow haven't talked to you in while. :cheers:
Old Mar 11, 2002 | 09:16 PM
jpee's Avatar
jpee
Bill :lol:
Hey JD.... He sounds like my kinda guy... ;) I'm sure if those guys came to NJ for a Fri night gamblers, & Sat day of racing, with the Corvette Challenge Sat night they'd have a ball...
Of course I'm a little "OLD" for all that excitement...but I'll try to keep up..
Old Mar 11, 2002 | 10:44 PM
J Z06's Avatar
J Z06
Default Re: wheel studs?? (Red96Coupe)
John P,
Right you are. I am sure they'd have a great time. The big inch vette dude sounds like He's quite compatible with you Mr Panuzzo :lol:. Maybe we'll have to twist their arms and get them to cruise up.
To wheel studs??
