1994 automatic vibration noise
Old Jan 28, 2010 | 02:03 AM
donkeydawn11's Avatar
donkeydawn11
Default 1994 automatic vibration noise
Hi everyone I had to repost this again this problem is driving me crazy.
I have a 1994 convertible automatic trans 165 k
I have a vibration from the area of the drive shaft in idle positions drive and park. I recently had it out because of the vibration problem. I replaced the u joints I didnt mark the drive shaft so I dont know if that makes a difference.
I check the shaft and made sure that the weights were in place. When I put the car up on jack stands it doesnt make any vibration at speeds or idle.
It is loudest when Im at idle in drive or park. What do you think this may be. I even tried to put an exhaust cloth between the exhaust and cross membre didnt help.
The noise is sometimes loud and it also sounds like something going in a circle and rubbing against something.
