1988 EGR Temp sensor
Jan 29, 2010 | 09:10 PM
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Sensor is in EGR tube, the wire pulled out of mine, ques
1 new ones don't seem to be available
2 can I reinsert wire?...solder it?
3 I assume it is necessary?
any help will be appreciated
Jack
Jan 29, 2010 | 09:36 PM
Jack...........as I live & breathe!
Hope all's well for you & yours!
I can't help your question though
Jan 30, 2010 | 12:25 AM
Quote:
Originally Posted by
jackdaroofer
F-Body one appears the same if you are feeling rich
http://cgi.ebay.com/ebaymotors/Exhau...item5ad559728f
jackdaroofer
May throw a Code 32 if not seen by ECM.Tells the ECM exh gas is flowing to intake Plenty have deleted the complete EGR system with no ill effects or codes
Jan 30, 2010 | 12:28 AM
Doesn't the wire and metal tip on it screw into the top of the sensor?
Jan 30, 2010 | 04:30 PM
Cruise-In I Veteran
Cruise-In V Veteran
86PACER
Yes it does
Jan 30, 2010 | 04:32 PM
Cruise-In I Veteran
Cruise-In V Veteran
Caboboy
Tim great to hear from you, I thought all us old ti,rtsd had gone away. Hope you are wekk and doing great. Ill send you an e mail
Jan 30, 2010 | 04:55 PM
jackdaroofer
Yes it does
I thought so. I remembered doing this same repair on mine years ago. I think I re-crimped mine.
Jan 31, 2010 | 08:08 PM
2021 C4 of the Year - Modified Finalist
I have recrmped and then soldered them, and they only last for a while.
I did buy a new one from a member here who got it from corvette central.
Feb 1, 2010 | 08:10 PM
Cruise-In I Veteran
Cruise-In V Veteran
Mine screwed right together, I have had it in and outseveral times and I quess it got loose
1988 ,
88 ,
c4 ,
corvette ,
egr ,
engine ,
l98 ,
repair ,
replacement ,
senceor ,
senser ,
sensor ,
switch ,
temp ,
tube
