no power under load??
Old Jan 30, 2010 | 11:38 AM
trickedout1's Avatar
trickedout1
Default no power under load??
i've got fuel pressure on rail, i've givin motor complete tune up, no change. i've also checked back pressure on exhaust, still acts like running out of gas under load and gets worst as motor gets hotter. what should i check next??
Old Jan 30, 2010 | 11:50 AM
Baron515's Avatar
Baron515
Cruising
What exactly do you mean by "under load"? do you mean it kind of stutters off the line?
I had a problem where the car would stutter, wouldnt have much power when I was trying to accelerate too fast.
I changed the injectors to BoschIII injectors and it did wonders for me. If you've still got the stock injectors Id suggest paying a visit to fuelinjectorconnection.com
There are more experienced members on here who im sure can give you more advice.
Old Jan 30, 2010 | 11:55 AM
HdRider04's Avatar
HdRider04
I just had the same problem took me 2 weeks to sort it out, Even though I had pressure at the rail I had a bad fuel pump, replaced the pump, sock and filter and all is well......
The car would be fine under easy acceleration but anything beyond that it felt like it was starving for gas and I had to back off the pedal.
Old Jan 30, 2010 | 11:57 AM
trickedout1
the injectors were replaced about a year and a half ago, when under load i mean in gear , it tries to stall, when acccelerating.
Old Jan 30, 2010 | 11:58 AM
trickedout1
i've installed new pump, filter , sock and pump wires
Old Jan 30, 2010 | 12:08 PM
desertmike1's Avatar
desertmike1
Unless you rig up a fuel pressure gauge that you can read while driving the vehicle, you don't really know what the fuel pressure is under a "Load" and this is were the highest fuel flow rate is, with this said I would start out by at-least changing the fuel filter for starters.
HdRider04's Avatar
HdRider04
Is it throwing any codes? have you checked the MAF and TPS?
Old Jan 30, 2010 | 01:10 PM
trickedout1
no codes, i,ve unplugged the maf , car tries to die and check engine light comes on, how do i check the tps?
Old Jan 30, 2010 | 01:12 PM
TWISTERUP's Avatar
TWISTERUP
you'll need a fuel pressure gauge w/hose long enough to tape it to the windshield while you drive--sometimes a weak pump can be hard to detect without doing this
Old Jan 30, 2010 | 01:13 PM
trickedout1
brand new pump
Old Jan 30, 2010 | 01:17 PM
aboatguy's Avatar
aboatguy
Check fuel pressure underload...I tape my gauge to the windshield and go for a spirited drive..
If fuelpressure is good....I'd check the Cats...a clogged converter can IDLE well and rev in park but run like butt under load .
Old Jan 30, 2010 | 01:19 PM
trickedout1
no cats on the car, new fuel pump
Old Jan 30, 2010 | 01:26 PM
TWISTERUP's Avatar
TWISTERUP
brand new pump
I'm basing my comment on your opinion that it feels like it's running out of fuel/gas---driving while watching fuel pressure is a way to determine if fuel filter is ok/new pump is ok/hose at fuel pump is ok and that the fuel lines aren't damaged/restricted in some way JMO
Old Jan 30, 2010 | 01:29 PM
trickedout1
i've installed new pump and screen inline filter, electrical in tank.
Old Jan 30, 2010 | 01:38 PM
ittlfly's Avatar
ittlfly
Craping out under load can also point to a coil breaking up. FWIW.
Old Jan 30, 2010 | 06:58 PM
ex-x-fire's Avatar
ex-x-fire
If you can get it to act up w/ the hood open, spray carb. cleaner into a small vacuum hose while you rev it, does it get better or worse?
To no power under load??
