Re: Pocket programmer with windows XP (LPDesRoche)
It says on their page that XP is supported, but I though most folks here burned in DOS.
That's no problem...Boot up with a DOS floppy boot disk...Lots of them at http://www.bootdisk.com
XP supposedly will not work with any hardware that requires direct access...fr'instance, my SB Awe64 card won't play the music or sounds from Doom...I would imagine any device that uses a program to write to an EPROM might not be reliable, if it works at all...
As with WinME, your best bet is the DOS boot floppy.
