Shift Points?
Old Mar 6, 2002 | 08:19 PM
vetteman32's Avatar
vetteman32
Default Shift Points?
What is the optimum shift point to get the maximum acceleration for my stock 6 spd LT-1? Should I be shifting at red line? or somewhere else? Is the optimum shift point the same for each gear or different for 1-2 vs 2-3 or 3-4? If I shift too early I'll drop too low on the power band, if too late I've gone past the peak and will decrease my rate of acceleration. Any ideas from you experienced guys?
Old Mar 6, 2002 | 08:46 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Shift Points? (vetteman32)
I would think 6000 is a good starting point.
Old Mar 6, 2002 | 09:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Shift Points? (mackeyred96)
Remember the factory tach is off by at least 200 rpm on purpose.
If you crank the volume up, you might be able to hear the engine.
Click below
http://temp.corvetteforum.net/c4/mrmojo2//shiftvid2.mpg
To Shift Points?
