Torque vs Horsepower
Have read that many time. It is a very good explaination.
That's why if you look a a HP vs FT lb they always cross at 5250
Torque is what gets the car moving Power at the low R's
H.P. get you that top speed
Think of this : motorcycles (Rice Rockets inline 4's)are fast they may very little torque but are stupid fast If you ever ridden one you've notice that there is no power down low it's all when you get going higher RPM's)
Now a Mac truck has a lot of torque it can pull tons of weight but we can agree that they aren't to fast.
The key is to have a good balance You neet the torque to get a goo launch (60' time) and you need the HP to run hard down the end of the track.
Having to much torque and not enough HP cause your car to fall on it's face having alot of HP and no torques takes to long to get going.
Hope that didn't confuse you to much
Assuming both cars weight the same, which is faster? Neither HP nor TQ is king...you have to see the curves.
Makes sense to me. :yesnod:
It's only a long, flat horsepower curve that matters.
H.P. IS calculated off of torque, thus if your torque falls on it's face, HP will go with it. That's why these ricers can make good PEAK HP numbers but still get killed off the line. They might not make much torque, but since HP is calculated off of torque & RPM, the HP numbers can be high. A car that makes 300 pounds of torque at 3000 rpms, has X amount of HP. Now if the same car could turn 300 pounds of torque at 9000 rpms, HP would be much higher.
So what you want is your TORQUE curve to be flat, and that will make the HP build in a straight line. A "flat" HP curve would mean that your torque fell off the face of the planet. Look at my dyno graph for example, if my HP curve was flat, my torque curve would have to fall as the RPM's get higher, you don't want that.
This isn't my latest dyno graph, but it's the best representation because HP and torque are plotted on the same scale.
What is important aside from peak numbers is the "area under the curve" This area works as your "total torque" and "total hp" the larger these numbers are the faster your car will be all around. A flat HP curve would be bad because it would mean a declining torque curve, when torque equals 0, HP equals 0 again as well, so you don't want that at all.
That's why these high reving imports are so slow off the line, they might put up some healthy HP numbers in the very high RPM's, but the rest of their revs are useless. Personally I'll take my 6300 rpm's that every inch of is useful and I can't hardly be in the wrong gear over one of thse 9000 rpm motors in which only the top 1500 does me any good.
