Can dings be worked out of OEM runner tubes? How? I was gonna maybe port/polish and then polish the outside.
Anybody ever thought of some type of coating on the insides to smooth things out instead of polishing? Powder coating maybe? Being in the air/fuel mix it would have to durable, pretty well flake proof. Just wondering out loud.
I had my SuperRam runners and manifold extrude honed. Opens them up and makes them as smooth as glass. There is really no air/fuel mix to speak of. Just air passes through the runners. The fuel is injected right before the intake port in the heads.
Someone on here went to a music store that repairs brass horns and they did the runners. They push steel ***** through the tubes to remove dents. I think somebody bought the ***** off ebay too and did it. Its been years but if you search you should find the info.
Be careful using those so you dont change the runner shape, easy to do. Dont worry about porting the inside of a stock runner they are thin so not much can be done. If you feel better taking a flap wheel to the inside knock yourself out but you wont gain anything. btdt
This was actually my first thought. Surely someone pulls dents outa trombones and tubas. I will hafta check and see if there is anybody near my BFE outpost.
TA-Thanks for that link, it would probly be cheaper to get this kit. Expanding out the thin a** runners is kinda scary but getting em back to round would be great.
Cuisinart- The runners are definately too thin to port but I was thinking more about gasket matching the flanges if needed. This thin-ness was why I asked about a coating. Insta-slick
Changing the runner shape is VERY easy to do. My first attempt left my runners looking like the Michelin Man. HOWEVER, the steel ***** do work! The trick is to use a grinder and remove the lip on the inside of the runner right at the flange so the first ball drops in at least half way or more. Then use a lot of oil and drive the ball through the runner with the smaller *****. I strongly suggest getting an old battered runner to practice on first. My runners came out perfectly round and smooth after using the kit I bought on ebay. The ***** will also remove the small clearance indentions the factory put in the tubes.
