engine swap
Old Feb 2, 2010 | 10:55 PM
Jackwmonk's Avatar
Jackwmonk
7th Gear
Default engine swap
will i have to change anything i have a bad motor in my95 so i want to put a 95 truck engine in it for now they are both 5.7 motors
Jackwmonk's Avatar
Jackwmonk
7th Gear
please help
Old Feb 2, 2010 | 10:56 PM
Jackwmonk's Avatar
Jackwmonk
7th Gear
i want to put a 1995 5.7 truck motor in my 1995 vette temp. will i have to change anything
Old Feb 2, 2010 | 10:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
Your 95 eng is totally different than your truck engine. Block, heads, intake, ign system etc. They are the same displacement thats about it.
Old Feb 2, 2010 | 11:00 PM
Mark85Vett's Avatar
Mark85Vett
we need more info...it will bolt up but computer would have to be swapped a s well as entire wiring harness
Old Feb 3, 2010 | 09:27 AM
surfer92's Avatar
surfer92
Are you talking about the 5.7 Vortec?
Won't work, if you are.
Why can't you rebuild yours?
What is yours doing?
You can use a F body or a caprice LT-1.
To engine swap
