Water Pump?
Old Feb 3, 2010 | 11:02 AM
lbrehm02's Avatar
lbrehm02
Default Water Pump?
I have been having my low coolant light come on from time to time. Noticed air in the system. I also put a new thermostate in and noticed no water in the top radiator hose. started engine and the bottom radiator hose stays cool top gets hot but no water flow. I pulled top hose off and started engine and no fluid comes out. Is this a bad water pump? if so how easy is it to change, thanks for the help
Old Feb 3, 2010 | 11:04 AM
lbrehm02's Avatar
lbrehm02
the year is an 89
Old Feb 3, 2010 | 11:41 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by lbrehm02
the year is an 89
I sent you a Private Message
Old Feb 3, 2010 | 12:19 PM
runner140*'s Avatar
runner140*
Sounds like you are getting air in your system. Lost the seal when you changed the t-stat? Didn't bleed the system? Need a new radiator cap?
Take your pick.
Old Feb 3, 2010 | 01:23 PM
pmihaltian's Avatar
pmihaltian
Slingshot
the year is an 89
Here are the proper cooling system burping instructions for an L98 engine.
To Water Pump?
