well the primary cooling fan motor went today.called napa got a new fan.original was made in canada.napa's was chinese.i install it.it doesnt come on wen switch tells it to, checked voltage there was 12v at fan plug and perfect grounds.original motor was noisy but functional.i call napa mgr and he said well u know those corvettes are known for alot of electrical problems.i said the original motor workd.he reluctantly sent another one.chinese of course.THE SAME PROBLEM. CHINESE JUNK.im going ac delco tommorow.or any other brand u guys have had good luck with.
yes i did.which was the frustrating part.i checked the connector plug too.my voltmeter said 12.2v on positive side of the connector wen relay clicked.i did the install at work .after fan motor#2 didnt work i reinstalled my noisy original.it functions on off wise perfectly.
