Dana 36 non-posi?
Old Feb 6, 2010 | 03:29 PM
jadedvette's Avatar
jadedvette
Default Dana 36 non-posi?
I just bought a complete rear end for a project I'm involved in, and I did not know GM made a C4 rear that was not posi? My 86' is a Dana 44 and I've had that apart a few times to change gears. I've seen the spring between the side gears that make it posi. Is the rear I bought a non-posi unit or did someone remove the spring? I'm guessing it's a Dana 36, I have not looked at it closely. Thanks, Joe
Old Feb 6, 2010 | 03:56 PM
jhammons01's Avatar
jhammons01
There is no spring. The Gears trying to spread apart under power is what pushes the plates together.
Old Feb 6, 2010 | 08:27 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
they are all posi
Old Feb 6, 2010 | 08:54 PM
JackDidley's Avatar
JackDidley
Dana 36 has a Bellville plate under the clutches on each side. It is a posi, just different.
Old Feb 7, 2010 | 09:53 AM
jadedvette's Avatar
jadedvette
Thanks for clearing that up. I'll have to take a closer look at it.
Thanks again, Joe
Old Feb 7, 2010 | 04:50 PM
856SPEED's Avatar
856SPEED
for that matter, I believe all Corvettes since the beginning (all years) are equipped w/posi-traction......someone correct me if I am wrong......would be interesting to see if I am wrong!
Old Feb 7, 2010 | 08:39 PM
1stL98's Avatar
1stL98
i think gm installed what they called an economy axle,if i remember corectly.the productin numbers were very low.i read this info in a c4 corvette facts article.
To Dana 36 non-posi?
