brain dead
Old Feb 7, 2010 | 05:39 PM
geogolf's Avatar
geogolf
Default brain dead
mind went blank on a L98 does the coolant enter the block from top rad.hose or bottom hose
Old Feb 7, 2010 | 05:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I should think it enters via the bottom hose and exits through the T-stat and the upper hose, else a stuck T-stat could leave the engine w/o coolant. Also the top hose can be above the coolant level.
Old Feb 7, 2010 | 06:44 PM
383vett's Avatar
383vett
Correct!
Old Feb 7, 2010 | 07:14 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
yea, remember the LT-1 is reverse flow, and the water enters the heads first to keep em cool so they can run more timing
Old Feb 8, 2010 | 12:16 PM
geogolf's Avatar
geogolf
Default coolant
thats what my brain thought also just needed to hear it thanks, hell to get old
To brain dead
