84 Display out-help
Old Mar 7, 2002 | 02:32 PM
Loco25's Avatar
Loco25
4th Gear
Default 84 Display out-help
My 84 corvette's Display is out. I have checked the fuses. Also the odometer is not moving.
Any ideas on what the problem could be????? :crazy:
Old Mar 7, 2002 | 02:49 PM
hz900's Avatar
hz900
Default Re: 84 Display out-help (Loco25)
I fixed my cluster in my 86 myself. If it is the same problem try this. When you take the cluster out of the dash take it apart. There will be two circuit boards connected by I think it is 10 pins. Check the pins to see if one of them looks burnt at both ends of the connection. I can't remember which one of the pins it was but one of mine had broken loose from the board for what ever reason. All I had to do is soder the connection back and that fixed the problem. I think this is what happens to most of the dashes that just quit lighting up. Be careful not to damage one of the LCDs when you take it apart like I did though because those things aren't cheap and hard to find. I hope this solves your problem, but like I said this is what I had to do to mine, hard to diagnose yours without seeing it.
Old Mar 7, 2002 | 03:16 PM
vader86's Avatar
vader86
is the display totally blank or not lighting up at all (you can still see the numbers)
Old Mar 7, 2002 | 03:20 PM
Loco25's Avatar
Loco25
4th Gear
Default Re: 84 Display out-help (vader86)
totally blank....Doesnt light up at all
Old Mar 7, 2002 | 04:01 PM
GiDvEtTe84's Avatar
GiDvEtTe84
There is a web page that explains how to repair your dash, to a cetain extent. BTW, check out www.crossfire.webhop.net while youre at it. [:)]
Old Mar 7, 2002 | 06:35 PM
Loco25's Avatar
Loco25
4th Gear
Default Re: 84 Display out-help (GiDvEtTe84)
Gidvette84- where is the website you mention? BTW-checked out crossfire, waiting for them to send me my password
Old Mar 7, 2002 | 06:51 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Man, i dont remember the site. JonM knows it. See you at the CFI vault soon!
Old Mar 7, 2002 | 07:01 PM
JonM's Avatar
JonM
How's this for fast service?
http://www.corvettemagazine.com/1999...ash/dashp1.asp
http://www.batee.com/corvette/ :D
Old Mar 8, 2002 | 11:02 AM
GiDvEtTe84's Avatar
GiDvEtTe84
:yesnod: :D
Old Mar 8, 2002 | 01:20 PM
Loco25's Avatar
Loco25
4th Gear
Default Re: 84 Display out-help (JonM)
Thanks for your help....Hopefully I will be able to tell when I need gas soon :yesnod:
To 84 Display out-help
