Need help removing balancer hub
So I did perform a search and came up with some great resources.
However!
I can't seem to get the bolt out of the hub. I can get it loose but once it gets to what feels like the end of the threads it just spins and doesn't come out. I am not sure what to do since this is a major roadblock to removing the hub and therefore the seal.
Help!
Seems like you have a couple of crossed threads toward the end.
You can try a method of pulling on the bolt while, at the same time, turning it. An impact wrench, drill with a socket on the end, etc.
You could even try installing the hub puller and when the hub stops against the bolt, try turning the bolt more.
Grab the bolt head with some vice grips, pull and turn at the same time; wiggle and pull.
Sooner or later it'll come out.
Be sure to chase the crank threads once the bolt is out and, buy a new bolt to replace the one you have since it'll probably have a few dinged threads.
Hope this helps.
Jake
However!
Help!
Hope this helps.
93cruiser
Hope this helps.
93cruiser
I use progressively longer bolts like you mentioned, bottoming each one out as I go.
It's a pain, no doubt.
Most people use the stock bolt, or progressively longer bolts to re-install the hub. While that works 99% of the time, if you do it enough times you will eventually pull the threads out of the end of a crank. IMO, the "right" way to do it is with a piece of all thread, some kind of washer, and a nut. I wasn't able to find a washer that was heavy duty enough to work, so I got a piece of 1/4 inch flat steel from Home Depot. It was a strip about 2 inches wide and 3 feet long. I cut a 3-4 inch piece off the end and drilled a 1/2 inch hole in it.
My process is start the hub as best I can by hand. Then bottom out the all thread. Next, slide the flat steel plate I made onto the all thread. Install the nut and tighten. The flat steel should press against the hub, tightening the nut should push the hub on.
This method speads the load over the maximum number of threads, and helps make sure you don't yank the threads out of the crank.
Some people heat the hub to ease installation. I've tried that and if I get the hub hot enough to make the install easier, I always end up cooking the seal and causing a leak.
Anyway, that's how I do it. Your results may vary.
So I managed to get the bolt out and took the washer off as per instructions that I found here: http://forums.corvetteforum.com/c4-t...-a-92-lt1.html
It seems unless I bottom out the crankshaft bolt that I can't stop the bolt from turning as I turn the jackscrew. Not sure what to do now but I'll keep experimenting. It seems like I should just bottom out the bolt and keep turning?
