Side glass tracks.
Old Feb 11, 2010 | 02:02 PM
b54406barrel's Avatar
b54406barrel
Default Side glass tracks.
When I had the 95's door panels off last weekend, I noticed that there is a captured roller to raise & lower the glass on. I also noticed that towards about the front third of the window, there is a round shaft that runs vertical in the door with probably what should have been a slider that bolts to the door glass, that captures that shaft. It looks like that part is broken off, both windows. Is this common and is there an upgraded replacement part to prevent this? Thank you!
