Need Help...
Old Feb 12, 2010 | 09:23 PM
hifivinmofo's Avatar
hifivinmofo
Default Need Help...
Just had a service engine soon light appear after driving my 95 auto coupe about 20-30 minutes. Slight ticking coming from the passenger side valve cover/intake manifold area Noise is barely noticeable and sounds like it it coming from the rear of the engine. Any suggestions or anyone been down this road and have advice to give? Just had Exhaust done no rear res (replaced with x) Spintech 9000 series mufflers 3inch in 3inch out. Mayby that could be a contributing factor?
Old Feb 12, 2010 | 09:27 PM
don hall's Avatar
don hall
Default svc light
When the 'svc. eng. light' appears, it means that a sensor has detected a malfunction, and a trouble code (DTC) has been set. You need to determine what code has been set by attaching a code reader to the diagnostic link under the dash.
Old Feb 12, 2010 | 09:31 PM
rodj's Avatar
rodj
Or a paperclip
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Feb 13, 2010 | 10:16 PM
hifivinmofo
Those dang air check valves on the egr... Problem solved.
To Need Help...
