is it my waterpump?
Old Feb 12, 2010 | 10:22 PM
rickslt4's Avatar
rickslt4
Default is it my waterpump?
So I drive my car on flat ground, on cruise control, the temp drops about 8 degrees when I down shift to 5th from 6th. I'm thinking the flow has reduced due to the lower RPM, duh, but would a water pump that's degrading give the same indications?? I changed the thermostat last year when this happened on a trip and it fixed the problem but I would have expected it to last longer then a year??
Old Feb 13, 2010 | 05:42 AM
LindenBob's Avatar
LindenBob
Have you ever cleaned the debris out of your radiator fins? Bottom feeder highway vacuum ya know.
Old Feb 13, 2010 | 08:15 AM
ex-x-fire's Avatar
ex-x-fire
What temps you running? In 5th the engine will be turning alittle faster, so the wp would be too. It takes a very poorly maintained cooling system (lotsa rusty looking coolant) to erode the wp impellar.
Old Feb 13, 2010 | 08:16 AM
rickslt4's Avatar
rickslt4
yep, I try and keep it clean, it does have a new radiator but that was replaced way before I noticed this trend. Just thought maybe somebody else had seen this, I've searched but couldn't find any info. I have about 99K on the car so maybe I'll just change the pump and opti for good luck. (gives me a chance to clean in there!!)
Old Feb 13, 2010 | 08:45 AM
LindenBob's Avatar
LindenBob
Well good luck You are right about that. Can do some major cleaning with that stuff out of the way.
To is it my waterpump?
