'84 Belt Tensioner
Old Feb 15, 2010 | 10:23 AM
HlhnEast's Avatar
HlhnEast
Default '84 Belt Tensioner
Can I take the belt tensioner off by taking the big nut in the center off the AC bracket or does the whole bracket need to be removed? Will it uncoil or damage it with removing the big nut only?
Thanks!
Old Feb 15, 2010 | 12:01 PM
jhammons01's Avatar
jhammons01
What are you talking about now?
OK, that tension-er has the one mounting bolt that goes through that large bracket. Once you take the serp belt off there is no tension left. So, nothing happens.
The reason your wanting to remove it???
I'll take a stab and say that the bearing is bad or rough sounding.
The new Tensioner is ~$60 but at NAPA, you can find the bearing that goes inside for ~$11.
You have to drill out the three rivets that hold the pulley together....replace the bearing and use either new rivets or just a nut and bolt in place of the rivet.
Just saved you $49 bux.
Old Feb 15, 2010 | 12:13 PM
HlhnEast's Avatar
HlhnEast
Thanks J, I am parting the '84 out and someone bought the tensioner. Just didnt want to screw it up.
Old Feb 15, 2010 | 12:30 PM
jhammons01's Avatar
jhammons01
aaahhhh too bad for an '84
Another one bites the dust.
Old Feb 15, 2010 | 01:30 PM
pmihaltian's Avatar
pmihaltian
Slingshot
The one bolt holds it in position. It is torqued on there at 65 ft. lbs. so it takes a little elbow grease to crack it, but then it comes right off.
To '84 Belt Tensioner
