FastChip
Old Mar 8, 2002 | 01:00 AM
Bradley3's Avatar
Bradley3
Default FastChip
What do these chips do for nearly stock '92 cars?
All I have is exhaust, 160 degree thermo and I will be getting 3.54 gears as soon as spring decides to get here.
Is a chip worth it for me? What will it do?
Old Mar 8, 2002 | 01:10 AM
vader86's Avatar
vader86
Default Re: FastChip (Bradley3)
it will just turn your fans on earlier basically, i would wait unti you do some other mods before going for the Fastchip
Old Mar 8, 2002 | 01:15 AM
buppies's Avatar
buppies
They{ Fastchip }do a little more than just cut the fans on earlier I know from talking to Ed Wright that the rev limiter is increased to 6200 RPM I have this mod on my 92 and am pleased
Old Mar 8, 2002 | 07:14 AM
93 ragtop's Avatar
93 ragtop
Default Re: FastChip (buppies)
It moves the TC lock up from 41 to 50 and Ed says he tweaks the ASR.
Old Mar 8, 2002 | 07:23 AM
webmstrjay's Avatar
webmstrjay
Default Re: FastChip (Red 86 4+3)
Doesn't anybody sleep? Man, I thought I was up early. Do you still have to buy a custom chip for a stock setup? I don't plan on a lot of upgrades (K&N), but I would like the fan to come on a bit earlier and more aggresive shift points.
Old Mar 8, 2002 | 07:59 AM
93 ragtop's Avatar
93 ragtop
Default Re: FastChip (webmstrjay)
Well I go to bed early, just get up about 4. The main reason I bought the chip was for the lower fan settings. I noticed on the few runs I made at the track that the vette was fastest on the first run. The temps was still down around 190 or so. At 220 it looses time. The fan switches for automatically turning on the fans at a lower temp dont seem to be available for the LT1. By the way, I bought mine used from a forum member. $125.00 shipped and included the air foil and a LT1 throttle body cover plate.
Old Mar 8, 2002 | 10:00 AM
jpee's Avatar
jpee
Red 86
Your right, IT WILL run faster, the BEST temp is to try & leave the starting line at 140... I have a manual switch, so I can run my fan with the motor OFF, & cool it down while I'm in the stageing lanes..
To FastChip
