Passenger Side Half Shaft Id Plate?
Old Feb 15, 2010 | 12:30 PM
dry's Avatar
dry
Default Passenger Side Half Shaft Id Plate?
Ok who knows what the plate attached to the passenger side half shaft is there for and what do the numbers represent? There is not one on the drivers side half shaft.........
I am trying to decode the factory tag attached to this half shaft anybody know where to start.....it looks like one of the numbers is the vehicle vin and the other seperate numbers are a 4 digit and the other a 3 digit (8YP).
Any ideas hoe to decode these on a 1989?
Old Feb 15, 2010 | 12:59 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Do you have a photo of the tag?
Old Feb 15, 2010 | 01:07 PM
dry's Avatar
dry
I can take one maybe this evening, but it is the factory attached plate in the center of the half shaft........I know on the 1987 the 3 digit number on the passenger side half shaft was the gear ratio code, But on this 1989 the 3 Digit (8YP) does not appear to be a ratio code.....Just wanting to decode the numbers.......
Old Feb 15, 2010 | 01:15 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Yes, I understand what you are trying to do. I'm just thinking that if you have a photo of the tag, I can post it to the NCRS Technical Forum for you and see if any of the senior judges can decode it for you. Just trying to help...
Old Feb 15, 2010 | 05:42 PM
dry's Avatar
dry
That would be even greater.......I will see if i can get a pic this evening and post up
Old Feb 15, 2010 | 06:02 PM
rodj's Avatar
rodj
I have 5 sets and both the drv side and pas side have identical tags / set
Of the 2 sets with # similar to yours, all four have the same # you reference as a possible Vin
The only difference between the two sets is the 3 letter code
one has L19 nc , the other I25 nc
I also have two completely different style of tags ; the bottom shown is from a later car and the tag is at the end , not in the center of the HS
Old Feb 15, 2010 | 06:15 PM
dry's Avatar
dry
same tag # as this one, what do the numbers mean??
Old Feb 16, 2010 | 04:55 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I posted your question and photo on the NCRS Technical Forum. You can follow it and see what the answer might be by viewing this address:
http://www.ncrs.org/forums/showthrea...76229&uid=7355
Let me know if you have any problems accessing this URL.
P.
To Passenger Side Half Shaft Id Plate?
