383 engine build, comp help
Old Feb 17, 2010 | 01:15 AM
Doughboy2k3's Avatar
Doughboy2k3
Default 383 engine build, comp help
Hey Guys
I am building a 383 and I want to keep the comp at 8.5 to 9.1.
Dish piston options avalible to me are -12.8cc dish or -20.4cc reversed dome. 6.0 rod on -12.8cc and 5.7 on -20.4cc.
4.060 bore
head options 65cc or 75cc
Also what head gasket would I use for 12 lbs of boost.
What combinations
Example -12.8cc, .046 inch gasket, 75cc head, = 9.5 comp ration.
Any advice would help. Thanks Guys
Old Feb 17, 2010 | 07:31 PM
AKS Racing's Avatar
AKS Racing
Originally Posted by Doughboy2k3
Hey Guys
4.060 bore
What combinations
Why 8.5-9.0:1 SCR? I mentioned in your other thread that if you are keeping the boost low, I would be targeting 9.3-9.5:1 SCR.
Old Feb 17, 2010 | 11:00 PM
HighMileage's Avatar
HighMileage
You should also be able to get a -31cc dished piston.
Check out this Golen Build:
http://www.gmhightechperformance.com...all/index.html
Golen ports stock heads (52 or 53cc LT1, 58cc L98) hence the piston dish size and design.
I think conventional wisdom suggests that with a wedge head design (23 degree Small Block) you go for a flat top piston and let the combustion chamber dictate your compression, so I think the more detonation resistant path is this way as I believe detonation can start in the quench area. I do not really know if this is the case with forced induction, but it is the case with normally aspirated.
The hard core guys machine the piston dish to mirror the heart shaped head shape for the ultimate racing engines. I know that is not your case here, but I guess it supports minimizing the dish.
For what its worth I have a -21cc dish 355 and 8lbs and no problems, but you are building from ground up.
I would also think a call to AFR would give you a good recommendation.
Hey Guys
4.060 bore
What combinations
Old Feb 18, 2010 | 03:47 AM
Doughboy2k3
I just get worried that I will start to stare at my car one day and say it could use five more pounds.
Old Feb 18, 2010 | 06:32 PM
AKS Racing's Avatar
AKS Racing
And you would be fine with a proper tune. An 8.5:1 SCR S/C'ed engine makes for one LAZY street car....
Old Feb 19, 2010 | 12:50 AM
Doughboy2k3
AKS,
I am going to go with a 9.1 comp. I had a feeling that 8.5 would be to low. I will take pics of the build and post them. Thanks, Walt
To 383 engine build, comp help
