TDC and optispark. Help!!!
Old Feb 17, 2010 | 11:02 AM
Goldenboyws6's Avatar
Goldenboyws6
Default TDC and optispark. Help!!!
To be on perfect timing...Do I have to set the TDC on cylinder 1 to install the optispark or I just have to worry about the pin and the slot? Thanks
Old Feb 17, 2010 | 11:10 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
No,Just line up the pin and the slot.That's is all. Sometimes rotating the engine some to position the dowel in a better place can help you to see it better at install.Straight up at 12:00 on the cam pin may be the best position so you can look straight down on it in squarely when leaning over the car.
Rick
Old Feb 17, 2010 | 11:50 AM
mikem350's Avatar
mikem350
Don't need to worrry about #1...Probably the only GOOD thing about the opti
To TDC and optispark. Help!!!
